Default how do i install the drivers on my mini 9 once i reload XP - 04-22-2010, 09:34 PM
how do i install the drivers on my mini 9, once i reload windows XP?
Default 04-22-2010, 11:29 PM
If you installed from the Dell restore CD, then you have them already. Otherwise you can download them from Dell.
Cool 04-22-2010, 11:52 PM
yes , like Steve said the drivers are available from Dell and are downloaded in executeable files so basically all you need to do it double click and follow the prompts, depending how new your Mini is you might wanna get the drivers from Dell anyway to make sure you have the latest versions, there might be updates from the ones on your Restore CD/DVD....
PS. Welcome to the forum....
Default 04-23-2010, 12:10 PM
thanks guys, but where would i find them to reinstall?
Default 04-23-2010, 05:07 PM
Click on the link in my post.
Default 04-23-2010, 06:26 PM
hey holmes4, i think i have the drivers installed, but now there seems to be network problems, for i can't connect to internet or connect to a network, any ideas?
thanks in advance
suffice to say, im computer illiterate as they come!
Default 04-23-2010, 09:32 PM
Wired or wireless? Have you tried the Network Troubleshooter in Windows?
Default 04-24-2010, 02:33 PM
wireless, seems something is wrong with my network controller driver or software?
Default 04-24-2010, 03:46 PM
You have to get the drivers from the other cd that they gave you. Insert the Drivers CD, then load the drivers for the wireless.
Black Dell Mini 9 w/Vostro A 90 trim 16gb OSX 10.6.3 3G WWAN Broadband (Runcore 64gb)
Asus 1201n Intel Dual Core N330 250gb 3gb ram Triple boot Osx/W7/Jolicloud
Default 04-24-2010, 05:15 PM
Is there a wireless connection icon in the system tray? Right click on it and select "Repair connection" or some such. Is the Mini "associating" with the router? Have you correctly entered the security information?
« Freezes & crashes after Closing and Opening lid; Win 7; reboot makes drive not found | Battery Lock Switch broken »
