psirna psirna is offline
Question update manager issues PLEASE HELP... - 04-16-2010, 07:22 AM
comes up as failed to fetch Unable to find expected entry main/binary-lpia/Packages in Meta-index file (malformed Release file?)
Some index files failed to download, they have been ignored, or old ones used instead.
it fails then says the system is up to date and was last updated 84 days ago problem is reoccuring and i would like to fix if anyone can help please do thanks MDM
its a dell mini 9 running linux/ubuntu i believe version 8.04
Default 04-16-2010, 05:03 PM
What does "/etc/apt/sources.list" look like? (It contains info about the servers to download software from in Ubuntu and related Linux distros)
It should be lines similar to these:
deb squeeze main contrib non-free
deb-src squeeze main contrib non-free
deb or deb-src, then a URL, then a list of components. Also, lines starting with a # don't count, 'cause they're comments.
snowpine snowpine is offline
Default 04-17-2010, 11:43 PM
Google doesn't support your LPIA architecture.
« Mini Overheating issue- Dell Depot update | Any Extra Webcam Assembly cables? »
