Default Problem playing full screen videos on plugged in monitor - 12-31-2008, 12:29 AM
I recently purchased a Dell monitor to go with my Dell Mini 9 laptop. But when i try and play full screen videos, the picture freezes although the sound keeps going. Is this a problem with my video card, my memory, or what?
Here are the specs for my computer:
-- Inspiron Mini 9 --
-- IntelĀ® Atom ProcessorĀ® N270 (1.6GHz/533Mhz FSB/512K cache)
-- [224-0770]
-- Memory --
-- 1GB DDR2 at 533MHz
-- [311-9255]
-- Video Card --
-- Intel Graphics Media Accelerator (GMA) 950
-- [320-7124]
-- Hard Drive --
-- 16GB Solid State Drive
-- [341-7610]
Default Re: Problem playing full screen videos on plugged in monitor - 12-31-2008, 01:23 AM
i think the problem is the video card. is it possible to install a better video card?
Default Re: Problem playing full screen videos on plugged in monitor - 12-31-2008, 12:34 PM
No - the video functions are integrated into the chipset. There is no "card".
Default Re: Problem playing full screen videos on plugged in monitor - 12-31-2008, 01:10 PM
hi steve, thanks for the info. do you know, or does anyone else then know, if there is any other solution to my problem? can i work around this somehow
Retired Mini user
WolfKeeper's Avatar
Default Re: Problem playing full screen videos on plugged in monitor - 12-31-2008, 01:15 PM
What kind of videos? Streaming or local? File or disc based? What player(s)? What codec(s)?
Getting an iPad
Default Re: Problem playing full screen videos on plugged in monitor - 12-31-2008, 02:31 PM
At what resolution and color depth are you running your monitor? Your choices may be a bit much for the integrated graphics.
Default 05-27-2010, 10:50 AM
Download the patch of Codecs (I Recomend K-lite Mega codec) search on google for it, and play the video on Classic Media Player to test;
Go to this site and verify if you have the Chipset newer version, if you don,t download it:
IntelĀ® Driver Update Utility
good luck!
Default 05-27-2010, 10:36 PM
Also, switch the display so that it's only showing on the external display, not both.
Better-Power 5200mAH for Mini 9 For Sale.
« Vostro a90 SSD failed...again. | EBIOS read error »
