So if I can still access the BIOS, should I be concerned with trying to recover it this way?
I am getting a similar EBIOS error. Media error Block Oxa8200 sectors 0.
I can still access the BIOS and boot order at startup.
I have tried booting from a flash drive with netbook bootmaker, and from external dvd using the netbook cd.
In both instances I get the same error.
If I let it startup directly to the
SSD it just sits there with a cursor.
I had snow leopard up and running fine for a couple of months, then all the sudden had a freeze and manual shutdown; never started back up.
---------- Post added at 04:43 PM ---------- Previous post was at 03:13 PM ----------
Ok, so I flashed the BIOS. I know it worked because it's now A05 instead of A04.
Unfortunately, when I try to run my boot disks I get the same result...
Any thoughts?
