Default mouse cursor is invisible - 01-27-2010, 02:48 AM
Just upgraded to Windows 7 Ultimate 32bit and sporadically on boot the mouse cursor is invisible. It IS there but invisible. I can keep rebooting and eventually get it to appear but not always. One time it wasn't invisible but instead was a large block about 2inches by 2inches.
I've seen this happen one other time on a Windows 7 computer and it was the HP mini netbook.
Anyone seen this before/know how to fix it? Google search didn't yield much.
Inspiron 11z | Core i3 U 330 | 8GB RAM | 1 TB HD | Windows 7 Ultimate x64
Cool 01-27-2010, 03:37 AM
sounds like it might be graphics card/driver issue..make sure you have the right drivers loaded..
PS. Welcome to the forum..
Default 01-27-2010, 02:49 PM
This is a common problem - I did not have it the first few times I installed Windows 7, but then it appeared on a later install. The general solution seems to be to enable "mouse trails" in the Mouse properties.
Default 01-27-2010, 10:22 PM
Installed the latest Synaptics touchpad driver and rebooted a few times with no invisible mouse problem. We'll see if it lasts...
TobyRhino's Avatar
Default 01-28-2010, 06:24 AM
I had a similar problem on a fresh W7 install. I think it was the Dell mouse drivers that caused it (although I did install all drivers and programs in one hit). Anyway, after touchpad drivers installed, I got my mouse pointer back - so you should be right.
« **HELP***Mini 9 Freezes-XP install from Ubuntu??? | Runcore 32 »
