sworsley sworsley is offline
Default mini9 wont switch to ext lcd - 12-12-2009, 09:14 AM
Hi, having problems with Dell mini9 on winxp
Using a VGA to HDMI converter cable into LCD tv
If I press FN and 8 the screeen on the 9 goes blank for a split second but nothng happens on the LCD
Any ideas ?
The cable is specifically to connect PC to HDMI tv...
Appreciate the help, thanks, Simon
Default 12-15-2009, 03:38 PM
Do you have a VGA-DVI adapter and a DVI-HDMI adapter connected in series? Won't work.
The digital part of DVI and HDMI is identical, making conversion a breeze. But HDMI doesn't have ability to carry analog VGA signals, while DVI does. So, the VGA signal gets stopped by the DVI-HDMI adapter.
If it's just a VGA-HDMI cable, it has to be specific to certain video cards. And not the Mini 9's.
« integrated webcam issues: dell mini 9 with ubuntu | "Operating System Not Found" Dell Mini9 »
