brynden29 brynden29 is offline
Default Re: blue screen - 12-04-2008, 01:57 AM
I would recommend booting to the resource CD and run the diagnostics. I had another system that would have random BSOD issues. Turns out it was the hard drive that had a few bad sectors and when the system tried to access it I would get the BSOD. I ran the diags and the hard drive seek test failed. May not solve your problems, but it could point you in the right direction.
Dell Mini 9, Red, 2gb RAM, 64 GB HD, 3 separate HDs: XP Pro, Vista, and Windows 7
Dell Mini 10, XPS M1530, Inspiron 1308, Latitude X1, Latitude D420, Latitude D610, Latitude D620, Latitude D810, Latitude XT2
Fallstar Fallstar is offline
Fallstar's Avatar
Default Re: blue screen - 12-04-2008, 04:09 AM
Thanks you guys (and sorry for hijacking this thread)...I found the minidump files, but I'm not techie enough to find the stop code within them, so I'll be taking my mini to work tomorrow, and let the IT have his way with my mini.
« Network problem | Screen Resolution changes on boot up »
