foxman31292 foxman31292 is offline
Exclamation SSD Failure - 09-13-2009, 06:29 PM
Well i have had my mini for about 2 days now and boguth a 2nd 16gb SSD. I installed it and procedded to install osx on the mini and it worked perfectly. I used it for about 2 days and then it froze up. I rebooted my mini and it proceeded to give me an error that no OS found. and media failure. I thought my SSD had failed so i replaced it with the 4gb that came in it from dell. Ubuntu booted right up and the computer worked fine. Does this seem like a SSD failure.
I read a post and saw that i should check to see if the SSd is seen in the bios. I am looking at the Fixed HDD value on the main page is None. This should mean that the SSD has failed and i need a new one right?
Default 09-13-2009, 08:04 PM
If another SSD works correctly, then the problem is almost certainly with the suspect SSD. And if the BIOS can't see it, then it's a hardware problem.
« Wireless Issues | logon failure »
