sam212 sam212 is offline
Default Screwed. - 08-08-2009, 02:34 AM
I know this has been covered in other threads, but I'm really at a loss here.
I cannot get one of the screws out of the SSD for anything. I've tried needle nose pliers, screwdrviers, and allen keys. I just bought a dremel, but I am weary to actually use it after practicing. Should I try the super glue way? Is there a way I don't know about?
dch dch is offline
Default 08-08-2009, 02:39 AM
If you stripped the screw head, your best bet is to get a screw extractor from the hardware store.
gospeed.racer gospeed.racer is offline
gospeed.racer's Avatar
Default 08-08-2009, 03:23 AM
file or dremel a slot. Glue wont be nearly enough. I have never seen a screw extractor that small.
Default 08-08-2009, 06:10 AM
Thanks. Finally just used the dremel. Typing this from my OSX mini9!
superann superann is offline
Default 08-10-2009, 09:47 AM
Had some trouble with mine too as they're (green) thread locked. Tried the screwdriver that came with my runcore and it was totally useless... almost stripped both. A smaller head screwdriver did the trick.
Dell Mini 9 white: OS X 10.5.8, v18.2 Touchpad drivers + BT "terminal mod", 2GB RAM, 64GB Runcore, 1.3MP webcam, US-intl U061h keyboard, BIOS A05, DellEFI 1.2a5
MikePA MikePA is offline
Default 08-10-2009, 09:07 PM
The Runcore screwdriver worked fine for me.
jetkins jetkins is offline
jetkins's Avatar
Default 08-10-2009, 09:31 PM
Mine too. Though a better screwdriver wouldn't hurt, the supplied one is perfectly serviceable as long as you apply pressure as you turn. But once the screws have been damaged, you'll want a better quality tool to salvage the situation.
White Mini 9 | 2GB Transcend RAM | 16GB RunCore | 16GB Patriot Class 6 SDHC | Internal BT | 1505 802.11n | BIOS A05 | OS X 10.5.8
Thinking of trying Dropbox? Use this referal link and we'll both get an extra 250MB of storage.
2-J 2-J is offline
Default 08-10-2009, 11:09 PM
I'm pretty sure it depends on the actual screws. I know how to use screwdrivers properly, and I used the Runcore-supplied screwdriver with a correct amount of pressure, and it was no go.
I have removed SSDs from two seprate minis, and it seems that some screws are just fixed tighter than others.
Black Mini 9: 64Gb Runcore SSD, Windows XP Home, 2Gb RAM, 1.3MP webcam, Bluetooth
« Another one with a battery problem... Should I downgrade the BIOS? | Loose battery and battery lock question »
