Jollydet Jollydet is offline
Jollydet's Avatar
Send a message via MSN to Jollydet
Default Re: Buzzing Noise from Display? - 02-07-2009, 04:40 AM
my mini makes zero noise. as confirmed by 2 sets of ears. :lol:
dexters_lab dexters_lab is offline
dexters_lab's Avatar
Default Re: Buzzing Noise from Display? - 02-07-2009, 03:00 PM
doubtfull it's the actual display as the mini9 uses an led backlight, unlike most other notebooks that use a ccft driven by an inverter, the inverter drives the ccft with a high voltage and sometimes they can buzz or whistle.
My guess is background noise from the speakers, tbh i think the mini9 has a feature where it disables the speaker drivers when there's no sound to kill any background hiss. I noticed this through the 'click' sound that xp plays when you click the mouse on certain links etc. If you disable this sound (under Sound & Audio Devices, Program Events, 'Start Navigation') it will mean unless your actually playing something the speakers should be silent
Black Dell Mini 9 2GB RAM/16GB SSD/16GB SDHC/BT/1.3M CAM/XPHOME
« Overheating / Wifi Issues | Spacebar not responsive »
