krivic krivic is offline
Default SSD dead - 07-20-2009, 10:23 AM
My SSD disk is dead. I cant inastall anything on it. I try all sort of programs fot partition and etc...use windows,linux,..and nothing. There is 0MB free i need new disk,but they are expensive. I decided to install mini pci adaptor with any of memory card (SDHC,...) so i have a question: it is possible to have SDHC card with any mini pci adaptor to boot windows from?
If anyone tested, please tell me od give me link from ebay, where to buy this stuff
thank to all
holmes4 holmes4 is online now
Default 07-20-2009, 04:15 PM
What OS did you last install on this SSD? The failure mode you describe is somewhat common. You should be able to get it replaced under warranty.
I don't know of an adapter that would allow you to use an SD card in the SSD slot. I have seen people use the WWAN connector for such an adapter, since it is wired for USB.
« Installing BT drivers | I need help... »
