Default SD card problem - 07-07-2009, 05:15 AM
I bought a 16GB SDHC card and plugged it into my dell mini 9 with OSX 10.5.6. The computer was frozen when I put it in. After rebooting the computer, the computer said that the card can't be readable.
I checked the SD card in the different computer with Vista. I worked well.
Is there any way to solve this problem?
faber78's Avatar
Default 07-07-2009, 06:58 AM
use vista....sorry, i had to.
spida505's Avatar
Default 07-23-2009, 03:12 PM
I'm running transcend 16Gb SDHC with OS X 10.5.7 - also OK under Windows XP. Card's class 6 and was found straight out of the packing. It's new, formatted FAT32 and can be seen equally well by both OS, as can contents of folders no matter which OS I make them in. Suggest you check your card is formatted FAT32 - OS X can't see NTFS. Maybe update to 10.5.7 as well? Also possibly update card driver in XP?
card reader, osx, sdhc
« Display backlight dead? | power led turns off »
