admisi admisi is offline
Default Control Wireless & Bluetooth with Commandline - 11-17-2008, 09:26 AM
For anyone interested, the Wireless Switch utility can be controlled by commandline if you want to set up batch files/script for turning on/off, or add Shortcuts to your Desktop.
The executable is "C:\Program Files\Wireless Select Switch>WssCmd.exe"
Here are the list of commands:
C:\Program Files\Wireless Select Switch>WssCmd /?
Wireless Select Switch.exe
Disable Wireless & Bluetooth
Enable Bluetooth only
Enable Wireless only
Enable Wireless & Bluetooth
Query Wireless & Bluetooth current status
Don't detect Wireless & Bluetooth hardware device
Vodafone Dell Mini, Black, Windows 7 , 2GB RAM, 32GB Runcore SSD, HSDPA modem, BT, 1.3 MP Webcam
ralphy ralphy is offline
Default Re: Control Wireless & Bluetooth with Commandline - 11-17-2008, 01:41 PM
Cool indeed. Might be very handy some day.
strider_mt2k's Avatar
Default Re: Control Wireless & Bluetooth with Commandline - 11-17-2008, 07:38 PM
Very cool trick.
One for the archives to be sure.
« Dell Mini 9 - Vodafone Questions | Any way to improve Wake from Standby? »
