ErasableRock ErasableRock is offline
Default Running hot? - 05-29-2009, 08:54 PM
Just got my Vostro A90, installed 2gig RAM, 64gig Runcore, and OSX Leopard. It seems to be running quite warm, Is this normal for this setup?
I had a maxed out 12" Powerbook that used to burn holes thru my pantiloons... so, Im fine with it being warm, Im just new to Dell hardware.
agianino agianino is offline
Default 05-29-2009, 10:19 PM
The Runcore does run hot, especially if you cover the vent holes. I use a cooling pad with mine.
« pidgin & msn | There is no Pause button - Or is there? »
