GISJason420 GISJason420 is offline
Talking OS X 10.5.1 7GB SSD - EFI Fixes & Audio Fixes - 04-22-2013, 06:07 PM
Hello Testers!,
Just wanted to see if anyone knew of the correct revisions / versions of the DellEFI app that I could use with OS X 10.5.1 I have got this Mini 9 working off a fresh install of 10.5.1 and the space available isn't grand but I can make do with it if I can at least figure out the correct revison of the Dell EFI app that will WORK/RUN under 10.5.1 so I WON'T have to actually update or try slimming the system even more as is. I've already ran mono which did great and freed up literally a GB. Now trying to just find the bootloader suitable to install onto the SSD Partion as is and have the audio fixed then this mini 9 is rockin ready. Thanks for any replies or recommendations.
« just found my mini 9 again | Install Linux to SD card »
