agd agd is offline
Default I Found a Replacement Mini 9 Battery That Works! - 12-02-2011, 03:32 PM
Like some others on this forum, I have had a hard time finding a compatible replacement battery for my Mini 9. Dell no longer has any in stock and two other after-market batteries I tried gave the start up "not recognized" messages, flashing lights and no-charge faults that have been complained about here.
I finally found a battery at CBK Laptop Repair in Mississauga, Ontario, Canada that worked perfectly with my Mini 9 using BIOS A04. It is the regular sized battery, so I can maintain the light weight and compact size that are the great appeal of the Mini 9.
Here is a link to their internet site:
http://cbkcomputer.com/
I hope this saves some leg work for others in my situation.
Andy
Nicchen Nicchen is offline
Nicchen's Avatar
Default 07-08-2012, 09:36 AM
Unfortunately this brought up an error 404 page. I will keep looking but for my own reference, what was the name and specs of the battery you purchased and is it still going well?
Fox Mulder Fox Mulder is offline
Default 07-11-2012, 11:30 AM
FYI this post is 6 months old and the user has not been on the forum since. Don't expect a reply.
Nicchen's Avatar
Default 07-13-2012, 10:55 AM
No worries, thanks for that. I've only had my mini9 for max. 2 weeks and have been trolling the forum for all kinds of information and advice. Every day i am learning new things; upgraded the RAM, HDD, OS, installed all new drivers and last thing for me is to get a new battery. Will keep trolling!
cholywell cholywell is offline
cholywell's Avatar
Send a message via Skype™ to cholywell
Default 12-20-2012, 03:32 AM
I just bought one from intelligentbatteries.com and it works flawlessly with bios A05. They are out of Vancouver I believe and it only cost $30.
Dell Mini 9 | Xubuntu 12.10 | 16GB KingSpec SSD | 2GB RAM
rayver0723 rayver0723 is offline
Default 02-22-2013, 11:59 PM
i was attempting to use a mini 9 i bought off ebay a year ago. along with a 3rd party battery that wouldnt detect. i downgraded bios to A00 using the biosflash v1.51 through usb. the flash change went through but still the battery wont charge and get the flashing orange/red lights. very frustrating. im thinking its not worth it to invest spending more money to upgrade an older laptop. it also has a 4gb ssd with tinyxp loaded but only 800 mb space available. do have an wiped clean 8gb ssd (from an older mini 9 that i cracked the screen and failed to attempt fixing) i loaded ubuntu onto that ssd. 8gb ssd seems too small to install windows xp, i tried.
i could probably sell it on ebay. surprisingly i see mini 9's still going for decent prices. mine is in good condition only the battery issue and small ssd (4gb or 8 gb). and maybe use the money to upgrade to a mini 12 possibly. for the most part the mini 9 has been sitting there collecting dust and rarely used. but if i could just fix this battery issue and get a larger ssd pretty cheap i dont mind keeping the mini 9 as a backup/travel netbook
cbrguy cbrguy is offline
cbrguy's Avatar
Default 11-05-2014, 04:18 PM
The site is working and they have Mini 9 batteries for C$39.00
Battery for DELL Inspiron Mini 9 910 9N UMPC 8.9 W953G - CBK Computer Inc.
I guess this is a Canadian site?
Mini 9|2GB|16GB SSD| Intel 6235AN | WinXP Pro - eBay: 9/28/2012
Mini 10v|1GB|160GB HDD|WinXP Home - eBay: 11/4/2014
Default 11-06-2014, 01:00 AM
I would be cautious about that site. It has no location information - the only hint is, as you suggest, that it might be in Canada due to the C$ in the price. But the whole web site is generic and pages such as the Terms and Conditions are blank. It's using a GoDaddy "Quick Shopping Cart" without much filled in. The only contact info is an email form.
cbrguy's Avatar
Default 11-06-2014, 02:21 AM
Yeah, it does look a bit hokey.
« 10.04 LTS and mic input | Android on Mini 9 »
