rayver0723 rayver0723 is offline
Default Mini 9 battery life declining - 06-01-2010, 03:06 AM
So ive had my mini 9 over a year now. My original hard drive died, was replaced over a month ago with a new one and installed the most recent version of ubuntu netbook remix. I only have wifi on, lowest screen brightness and I am lucky to just get around 2 hours. Is this normal for a 3 cell, 24.4 wh battery? Prior to the new hard drive and using ubuntu 8.04 i got easily 2.5 + hours. Also right now sometimes the battery gets hot, even when its charged enough, the red light starts flashing for a few seconds suddenly. Here's a youtube video that someone else had the same issue. So are these symptoms to a failing battery or something else? Thanks
YouTube- My Dell Mini 9 Flashing Red Light At Me
Product: Laptop battery
Status: Charging
Percentage charge: 81.0%
Vendor: DELL
Technology: Lithium Ion
Serial number: 11
Capacity: 100.0% (Excellent)
Current charge: 19.8 Wh
Last full charge: 24.4 Wh
Design charge: 24.4 Wh
Cool 06-01-2010, 03:20 AM
well getting about 2 hrs or so out of a 3 cell is about normal...did you buy it new or used...I mean after over a year or so you are gonna see some decline....those batteries usual last about 1 1/2 to 2yrs depending on how many charge/discharge cycles they go through...and I also think that the battery getting hot is shouldnt get so hot where it burns your hand, but if you have it on your lap...yes its gonna heat up...try a cooling pad underneath not only will it be more comfortable but I personally think it might extend the battery a little longer..just my 0.02....
Primadog Primadog is offline
Default 06-01-2010, 08:32 AM
My runs down to under 2hr after a year also, so it's probably pretty normal, which is why I have a 10hr one from mydigitaldiscount on the way. Let's see how it turns out.
Default 06-04-2010, 11:12 AM
The more you use the battery the faster it dies - if you do constant and regular full discharges then it will just die faster.
And if you leave the laptop in a stored full battery state then you will lose 20% capacity per year - they are best stored at 40 - 60% charge then they will lose noticeably less, they also hate heat.
So over all their is nothing wrong with your battery it's just wearing out.
« What to do with dead mini9 | Where is the dell vostro a90? »
