dirtymoney dirtymoney is offline
Default Possible to use system restore on a mini 9? - 02-27-2010, 10:10 PM
When i enable system restore on my mini 9 and make a restore point. It deletes it later on. I assume its because there is not enough room to keep it.
System restore has saved my bacon in the past and I would like to have a single restore point saved so I can restore my system if i should have a serious virus infection.
Is this possible on the mini 9?
I am using xp. With everything pretty much stock on the mini 9. I DID however get a 16mb sdhc.
TobyRhino TobyRhino is offline
TobyRhino's Avatar
Default 02-28-2010, 08:47 AM
I'm not sure about only having one system restore point.
However, what I do is make a whole system image and store it on an external backup drive. I guess in theory it works the same, by having a working backup, but it's more trouble than sys restore. And it's only really handy if you aren't installing a lot of software.
You can change the size of the space allocated for system restore (System Properties > Advanced System Settings > System Protection), so through that you might be able to manually limit it to one restore point.
« Can't find touch screen kit for mini 9 anymore, will the kit for msi wind u90 work? | Service Contract $101 Worthwhile?? »
