macnoob macnoob is offline
Default Help!! installation issues - 09-25-2009, 01:05 PM
I had the mini 9 running mac osx something got screwed up and it wont boot now, which is fine ... whatever..
my issue is i want to put a watered down vista install on there. The mini wont boot the windows cd or flash drive.
when i put the files on a flash drive i get disk error m when i try to boot the cd it brings up the darwin boot loader, i type 9f for cd drive.. but it still tries to boot the mac os.
please help
bmcclure937's Avatar
Default 09-25-2009, 01:51 PM
What are your BIOS settings? Do you have booting from USB enabled?
Also, make sure you created the Windows installation USB properly.
Meklort's Blog | NBI Google Code Page | -- the best OSX installation guides
Default 09-28-2009, 04:32 PM
yes i have the usb enabled... it may be the usb is not setup correctly.. i used vlite to trim it down then copied all the windows files from the iso to the thumb drive
« DM 9 3 - 1 Card reader question | Can't install a new Windows XP on an used Dell Mini (Inspiron Mini 9 (910)) »
