robvalverde's Avatar
Default 11-30-2009, 04:52 PM
Originally Posted by charles.bc View Post
How can you physically disconnect the Wifi card? You dissassemble the Mini 12?
I also have this minor issue. I am testing to mute sound right now.
Yeah, you have to dissasemble the unit. It's explained on Dell's documentation:
Documentation
But, anyway, this NOT solve the problem. I just contacted Dell and I have to send the mini again. This time they will replace the sound card and the speakers another time. I'll mantain you updated.
Mini 12 - 1.6Ghz - 60Gb - 6cell - Windows 7
iMac 24" - 3.06Ghz - 4Gb RAM - 1Tb
Default 12-26-2009, 04:04 PM
Documentation
yeah~~ please keep me update also. Im having the same problem. Like water boiling sound come from left lower side~ but i saw the photo of a dismantle mini 12...there is no hardware on the lower left part~weird~
Default 12-28-2009, 03:52 PM
Well the things ended bad.. I received again the netbook with a letter saying "the computer it's ok, no issues found". Then I've contacted again by mail and they told me "based on the mini12's design, the sound it's ok". So, it's a DESIGN FAULT. And they gave me no solution, the case is closed.
I told they -in a polite way- that I won't buy any Dell product. And this is what I will do. I will try to sell my mini12 cause I'm not satisfied with it.
I hope this helps anyone
  (#14) Old
Default 12-28-2009, 06:20 PM
what a bad solution from dell...
  (#15) Old
Default 01-30-2010, 06:06 PM
That noise really began to drive me crazy!
It is the only issue I have with my Mini 12.
To fix that, I tried to understand the problem. It comes when the sound chip is disabled (for energy efficiency). Then, I try to seek for a solution.
1. First, I checked if it was possible to remove the deactivation when on idle. On Mac OS X, I know that this type of request is possible, but on WinXP, I don't think so.
2. I tried to change as many options as I can in Control Panel, no results.
3. Ultimate solution : Trying to apply as many as possible actions sound in Sound and Audio Device of Control Panel of WinXP. Per example, in Opera (web browser), I add the sound "Windows XP Menu Command.wav" to many actions. Then, when I browse the web, each time I open a page and when the page loading is over, the sound occurs and the windy annoying sound is not.
Anyone has other tips ?
  (#16) Old
Default 01-31-2010, 07:48 AM
A known issue with realtek sound is static noise.
The common solution is mute PC Beep and/or Aux in Sound Properties Playback
Alternatively, try a different driver. I have read that some drivers do not have problems, but this may just be from the act of changing the driver.
  (#17) Old
Default 02-01-2010, 04:12 AM
Thanks.
Which driver do you suggest?
I looked at Realtek website, but the provided software isn't a driver only file.
Have you find the solution of changing the driver to fix the issue for yourself (and your Mini 12) ?
  (#18) Old
Default 02-01-2010, 07:55 PM
Thanks.
My mini 12 sound is fine as I use linux.
Have you tried the PC beep/Aux muting?
I have solved this issue on another laptop with nearly identical realtek and nearly identical whining sound by rolling the driver back to an older version.
  (#19) Old
Default 02-01-2010, 11:05 PM
I have muted PC beep. Still a windy sound.
The current driver for the Realtek ALC268 is 5.10.0.5688.
I haven't found anything else.
Any links?
« Slow Start Up | HDD died what do i need to read it through usb? »
