Default HDD died what do i need to read it through usb? - 02-12-2010, 12:08 PM
Hi I dropped my mini 12 while it was on and the hard drive is fooked wont boot into windows, so i decided to take it out get what data i can off it and reformat hopefully. I brought a sata /ide cradle however the drive seems to be neither....is there a cradle or cable that converts it to ide so i can read it through a usb port?
Default 02-12-2010, 04:36 PM
you can take an external hdd case like this.
put in your hdd, and read your data out.
Good Luck.
mini10v | 10.6.3 | 2GB RAM | 64GB SSDNOW V-Series | NBI 0.8.4RC1 | A06 | BT:no | WAKEn LEGACYff
Retired Mini user
WolfKeeper's Avatar
Default 02-12-2010, 04:41 PM
You are correct, that drive's connector is not a standard connector (it's a ZIF connector, not PATA or SATA standard.)
You need a special connector/enclosure similar to this: USB2.0 Mini Enclosure for 1.8" ZIF Hard Drive (the link the previous poster provided will not work.)
Otherwise, hope you have a backup somewhere.
Getting an iPad
Default 02-12-2010, 09:26 PM
thx mate!! thats exactly what ive been looking for...now to find a distributor in australia
Default 02-12-2010, 10:14 PM
I'd use the Mini 12 itself as a drive enclosure. Boot off a USB drive or USB CDROM (I'd use a Linux LiveCD), then copy files off the HDD to a USB drive or network share.
« annoying noise - sound driver? | Mini 12 ... ridiculously slow? »
