mobilerobo mobilerobo is offline
Default 56wh 6 cell battery??? - 06-19-2009, 10:38 PM
I'm buying a dell mini 10v. Is it worth upgrading to a 56wh 6 cell battery instead of the 24wh 3 cell one that the standard mini 10v comes with? Trying to save money here...
ChazB ChazB is offline
Send a message via MSN to ChazB Send a message via Skype™ to ChazB
Default 06-20-2009, 04:41 AM
It depends on how much you plan on running it off of battery power. If you'll likely not have it plugged in much, you'll want the 6 cell battery. Otherwise the 3 cell will be fine if you plug it in all the time.
| Dell Mini 10 | Product Red Edition | 1.6GHz | 1.3MP | 160GB SATA HDD | Bluetooth | 802.11n | Windows 7 Ultimate |
| Dell Mini 10v | Obsidian Black | 1.6GHz | 2GB Kingston HyperX | 1.3MP | 160GB SATA HDD | Bluetooth | 802.11n | Windows 7 Ultimate |
Eagles may soar, but weasels don't get sucked into jet engines. - Unknown
Before Elvis, there was nothing. - John Lennon
« 9 AC adapter in 10v? | Bios Update OS X? »
