daring daring is offline
Default Left speaker overheating. Cause? How to Fix? - 07-09-2011, 11:22 PM
My left speaker is overheating. So much so that it melted. I installed a replacement set, and the problem still exists. Any ideas? Is this a sound card issue? Is it possible to replace the sound card?
Cool 07-10-2011, 02:24 AM
speakers do not overheat, there must be something around it causing it, there is or should be so little going into a speaker to cause it to have other issues....
PS. Welcome to the forum......
BTW: I believe that the sound "card" (dont think it has one) is built in to the mobo
Default 07-10-2011, 03:00 AM
Thanks for the reply. Yeah, I was afraid the sound card was built in to the mb. The speaker is definitely the heat source though, I used the computer for a week or so without speakers in it while I waited for the replacements, no heat. Plugged in the replacements and within seconds the magnet on the the left speaker was hot to the touch, after 30 secs hot enough to cause a blister on my finger.
overheating, sound card, speaker
« BIOS Setup access | Mini 10v screen swap question »
