lmftmf lmftmf is offline
Default Bricked Mini10v PLease Help! - 04-21-2011, 04:14 PM
Hi all, I had a problem with my battery so i decided to try and flash the bios. It wouldnt flash because the battery would not charge. I used a dos version of the flash and it got to the end and said that the bios didnt match what was supposed to be flashed and then it groaned and started to beep and recover it with crysis recovery. I need to find out if i can recover this netbook via usb as buying a usb floppy is not an option. Ive tried to search google and these forums numerous times. any help is appreciated.
« Dual Boot - OS X already installed | The battery cannot be identified »
