Default Will this hard drive work with my 10v? - 12-17-2010, 07:09 AM
The original hard drive that came in my mini 10v is giving me cyclic redundancy check errors so I decided it was time to buy a new hard drive. From reading through threads on this forum, I understand that the ideal hard drive for a mini 10v is 2.5" 5400rpm sata.
I found a 500gb hard drive on amazon for $53 and that sounded like it was really good deal for a Western Digital drive. Before I dropped the cash, I just wanted to make sure that I'm not missing something and that the drive is compatible with my mini 10v.
The drive I was looking at can be found here: <http://www.amazon.com/gp/product/B001JSSDGU/ref=twister_dp_update?ie=UTF8&psc=1>
If it isn't compatible I would love to know why, I don't really have a good understanding of hardware and would like to change that.
Default 12-17-2010, 12:32 PM
I think virtually all 2.5" SATA drives should work in the 10v. Hard drive, SSD, 5400rpm or 7200rpm.
The only exceptions I know of are the super-capacity, taller 12.5mm drives, and WD Velociraptors (not intended for laptops in the first place). The normal capacity (9.5mm tall) drive you're looking at should not be a problem.
Default 12-18-2010, 01:05 AM
Thank you for the reply! I just ordered the hard drive, hopefully it'll be a nice improvement to go along with my ram upgrade.
« New here and need help...win7 to XP | Is the mini 10 faster than the mini 9 (real world vs benchmarks)? »
