(#4)
| Junior Member Posts: 2 Join Date: Sep 2010 | You could always get some compressed air and spray out the ducting. Its possible it is just clogged up with dust and stopping airflow. Its also worth just checking the fan is still going round. If not that might be the part to be replaced. MyPCHealth |
(#5)
| Super Moderator Posts: 2,749 Join Date: Aug 2009 Location: Upstate New York, U.S of A. | Quote:
I use this: ![]() works great...runs off USB and doesnt deter battery life at all...also it fits nicely into my case...retails @ Bestbuy for about $25 (USD) http://www.bestbuy.com/site/Targus+-...pad&cp=1&lp=11 ![]() | |
« New Dell Mini 10v bluescreen error,"NMI: Parity Check / Memory Parity Error..."
Replace LCD in 10V Screen Resolution? »
