Default Wireless not working - 09-19-2010, 03:10 PM
Hi:
My daughters Mini was riddled with viruses, after many tribulations I got rid of them all. Evrything now works normally except I have no wireless- when I try to connect I get a "windows cannot configure this connection" error message. I visited the Dell support site, and tried the Windows fix they suggested but to no avail. I looked in the control panel and it told me my "radio"was not enabled, I clicked the "enable" box but still no connection-the next time I checked it it was "disabled "again. I reset the BIOS to the "default" settings-still nothing.
Is there a driver update or something I should download? and, if so, how do I install it?
Any help would be appreciated. Thanx
sincerely, Bruce in Dorset/UK
Default 09-23-2010, 04:46 AM
recommend downloading the driver from support.dell.com. Once you download it, click run. It will create a dell/drivers directory and extract the files there then autorun. You will be required to restart the machine then log back in to your wireless network.
« Adding Bluetooth to the 10v | is the 1024x600 lcd in the 10v the same as the one in the 1012? »
