josephpriboi josephpriboi is offline
Default Hard disk space problem - 07-13-2010, 06:45 PM
I have Dell mini 10v with a 160 GB harddisk.
I use Ubuntu Netbook Remix.
The problem is that it shows
So basically on my 160 GB harddisk I can only use 125.5+11.1=136.6 Gbs of space.
Is this normal?
Default 07-13-2010, 06:56 PM
Yes, the HD manufacturers count bytes different than the OS. The HD manufacturers use a decimal count, while the OS uses binary. Either way though you still end up with the same amount of of available bytes for storage.
Default 07-13-2010, 10:21 PM
As stated above, hard drive manufacturers advertise capacity in metric GB, but software traditionally uses binary GB. Software that uses binary should use the unambiguous prefixes: MiB, GiB, etc. to refer to binary units.
If you want a authoritative answer, run "sudo lshw -C disk" in a terminal to "list hardware, just disks". It will show you the raw capacity of your drive in both binary (GiB) and metric (GB). "sudo lshw -C volume" will show you how your disk is divided up. I think the Ubuntu installer defaults to 2 partitions, a swap/virtual memory partition of a couple GB (for when RAM is low), and a large partition for everything else.
ubuntu hard disk mini 160
« Problems with Wireless N card | Mini 10v Win7 starter image issues »
