Prezelman Prezelman is offline
Unhappy Problems with Wireless N card - 07-12-2010, 04:57 PM
Just a few months ago I purchased a wireless n card for my dell mini 10v and it worked wondrously but after a few weeks it would sit and try to "acquire ip address" and then eventually come up with the yellow exclamation mark triangle. After numerous attempts to fix it I gave up and put my old card back in. Well I decided to go ahead and try it again but I am getting the same problem. What is causing this and how can I fix it?
Default 07-12-2010, 06:34 PM
Have you tried it on other wireless networks or just your own?
You can check for a firmware update for your wireless router also.
Default 07-12-2010, 07:52 PM
What card? Anecdotally, "Intel" cards from eBay tend to be problematic.
Default 07-12-2010, 08:06 PM
Well it just randomly started working. I had this problem before while dual booting with ubuntu and at first it stopped responding on ubuntu and then xp. Now I only have xp on my mini until I can figure out how to get windows 7 to install right on my computer, so after like 30 mins of "acquiring the ip address" it connects flawlessly. I had heard that ubuntu has caused some problems with the wireless so Ill just stick with windows 7 and then dual boot google os when they release a steadier version.
« Is anyone going to try Froyo | Hard disk space problem »
