| Junior Member Posts: 5 Join Date: Jun 2010 | Hi! I finally got a mini 10v firmware A05 and installed osx without any problem thanks to the info I found on this forum ![]() Now I wanted to get a 6 cell battery so I bought this one on ebay. I plug the battery, turn on the computer and the light flashed orange. Then I have a message "unrecognized battery type. You won't be able to charge the battery". Does anybody have more infos on this problem? Thanks! |
(#4)
(#5)
(#6)
| Super Moderator Posts: 5,774 Join Date: Nov 2008 Location: New Hampshire | There is no way to remove the check that I know of. With the Mini 9, that check was added in BIOS A02, but the the 10v may always have had it. If you can't get the third-party battery to work, I suggest getting a refund and buying a Dell battery. Mini 9|2GB RAM|64GB RunCore|Intel 5300|Windows 8 |
(#7)
(#8)
(#9)
| Senior Member Posts: 321 Join Date: May 2009 Location: Baton Rouge, Louisiana | The battery that Wal-Mart sells on their online store is a Dell battery. Its under 70$ and that includes shipping. The only small problem is it does not exactly fit in the 10V. You can do a little shaving on the battery pad and it will slide in with a snug fit. You will more than double your battery life. I went from 2 hrs; 15 minutes to six hours with the six cell. And I use the old 3 cell as a backup now. Hard to beat that kind of deal. fdalbor Dell Mini 1010 XP--10.04/Mandriva One/Joli 1.2![]() Compaq R4000 laptop AMD 64 Compaq SR2034NX AMD 64 |
(#10)
