(#21)
| Junior Member Posts: 10 Join Date: Feb 2010 Location: Manchester, UK | Quote:
![]() Will report back once it arrives! ![]() | |
(#22)
| Junior Member Posts: 22 Join Date: Sep 2009 Location: Brighton, UK | Quote:
I ordered this battery - delivered to the UK - cost me around £38 all in I think (which is good). However - it doesn't work! The battery looks like a proper battery but it doesn't say dell on it (all the other markings look correct though). Also it's not a perfect fit which made me think it might be the Mini 10 one - so was thinking about shaving some off to make it fit properly. The main issue though is that once I squeezed it in and turned on the 10v it went to boot up and then the power light flashed red and white. Then on screen a message appeared which said "this battery could not be recognised. the battery is unable to be charged. please press f1 to continue." All in all not good. Have contacted the seller for an RMA in the hope I can return it! | |
(#23)
(#24)
| Junior Member Posts: 8 Join Date: May 2010 Location: South Carolina | I saw this post so I will ask..did you have problem with the 6 cell battery locking into the computer. I purchased on Ebay and it will not lock in...turn it over and the battery falls out. Do you or anyone else know how to modifiy the battery so it will fit and lock into a 10v ??? Picture or photos would be great. Cheers Mates.... Capt. John J. |
(#25)
| Senior Member Posts: 243 Join Date: Jun 2009 | Yeah, if you read this thread there is a link to another thread that explains how to alter the battery to fit. The link you are looking for is titled 'Walmart mini 10 6cell battery' and is actually in the post at the top of this page ![]() |
(#26)
| Junior Member Posts: 8 Join Date: May 2010 Location: South Carolina | Yes..you are correct and i have read it three time, but I would like to see the picture.. they do not open and give an error !!! I am hoping someone can post them again as an attachment... Cheers... Capt JJ.... |
(#27)
You'll need a sharp knife and a little patience, just gently scrape to shave off a little, then try the battery. Repeat until it fits, incredibly simple - can't understand why they even bothered to change the design. | |
(#28)
| Junior Member Posts: 2 Join Date: Sep 2009 Location: Scotland | Quote:
Hmmm...... Mini 10v, BIOS A04, Arctic White, 2 GB RAM, 250 GB HD, BT, SL 10.6.3 | |
(#29)
| Junior Member Posts: 3 Join Date: Mar 2010 | Quote:
I've googled this problem and a few people have suggested flashing the BIOS, which I'm a bit nervous about doing considering I've hackintoshed my Mini 10V. Any other suggestions? Or do I just return it to the seller? | |
(#30)
