Default Mini 10v build quality not so great? - 03-18-2010, 06:17 PM
Hmm just received the netbook today and notice the fit/finish doesn't seem that good. When the netbook is closed I can press on the lid in certain spots and hear a "popping" sound from the lid. Almost as if though there are gaps in the lid........
Anyone else experience this?
Default Agreed - 03-27-2010, 05:56 PM
I sent back my new Mini 10v (just after I had received it) due to a rattle somewhere in the case. Sounds like a loose screw or broken piece of plastic rattling around inside.
ParanoidAndroid's Avatar
Default 03-30-2010, 04:45 AM
My 10v wobbles when it is placed on a flat surface, i have to put a folder to under one of the corners to make it stay still when typing.
Orbital's Avatar
Question 03-30-2010, 06:46 AM
mine does this too. it's like the whole thing is warped.
does this happen to anyone else? it's really annoying
Default Yes, I had this... - 03-30-2010, 10:56 PM
Much like the ram upgrade though, it requires you to be totally fearless. To fix, dismantle as per video instructions until you get to the bit where you remove the main board.
When mainboard is removed, sit your 10v on a flat table. If it rocks at this point, literally pick it up and gently bend the case (the bottom part) until the unit will sit flat.
Re-assemble your 10v as per second video instructions, at each stage ensure that your netbook still lays flat on a table (including when the screen is fully open).
My mini 10v now sits lovely and flat. Hope this helps!
Default 03-30-2010, 10:57 PM
woah! sounds dangerous! anyone else confirm this?
Default 03-31-2010, 01:31 AM
It would seem easier to just shave down or add to the little rubber feets until the unit become stable. If you happen to be going inside the unit for some upgrades, then I can see making the "tweak" as part of the process. Otherwise, it seems like a lot of work for very little gain.
KuoH
w7ox's Avatar
Default 03-31-2010, 04:01 AM
I'm happy with my 10v. Netbooks were never intended as high-end products.
Phil
ChicagoGOBLUE's Avatar
Default 03-31-2010, 03:47 PM
Phil
+1
I'm very happy with mine. I kind of knew what to expect with a ~$250 netbook, however.
Mini 10v | OS X 10.6.2 | 160GB HD | 1GB RAM
PS3 tag - ChicagoGOBLUE
jcoll81's Avatar
Send a message via ICQ to jcoll81 Send a message via AIM to jcoll81 Send a message via Skype™ to jcoll81
Default 03-31-2010, 07:43 PM
Phil
Same here. The quality is more than acceptable for such a low price.
Dell Mini 10v | 1gb | 120gb HDD | OSX 10.6.2
« World's simplest case mod! | noob from outside philly »
