Default Wireless connection problem...help? - 03-06-2010, 05:45 PM
Okay, so I installed Windows 7 on another one of my mini 10's the same way I did on the other 2 without incident and this one will not connect via the wireless adapter. When I diagnose it I get; "wireless capability is turned off" however the adapter is enabled, it just won't search for a wireless connection; it acts as if it is disabled. The F2 key doesn't seem to be working or enabling / disabling the adapter either. Internet access works fine by ethernet cable so I already downloaded the most current driver for the wireless adapter but it made no difference to my problem.
Please help.....THANKS!
Default 03-06-2010, 10:14 PM
Which wireless adapter? Did you install the Wireless Select Switch app?
Default 03-07-2010, 12:32 AM
Hmm...I thought mine had only one wireless adapter 1397WLAN mini card.....the other is a wifi card..(which i guess is wireless as well)
Didn't know i had to install anything after a clean Window 7 installation. I've done the same exact 7 install to two other identical units and I didn't need to install anything afterwards.
thanks!
Default 03-07-2010, 12:35 AM
What I meant was which brand and model WLAN/WiFi card do you have?
You need the Wireless Select Switch application to enable the F2 functionality.
Default 03-07-2010, 05:09 AM
Oh, no problem. Not sure of the brand or model.....sorry but, how could I retrieve that info?
Also, how do I enable the Wireless Select Switch and why didn't I have to do anything 'extra' in the prior installs on the same units?
Thanks again for the help....much appreciated!
Default 03-07-2010, 12:18 PM
I don't know why you didn't have to do anything different before. If you're using the stock Dell adapter, then don't worry about the brand and model.
Default 03-07-2010, 03:03 PM
Any ideas on how to fix the issue? F2 key / switch etc.
Thanks!
Default 03-07-2010, 04:25 PM
Default 03-07-2010, 05:00 PM
Okay, so I downloaded the drivers and nothing changed, same problems. Thanks for the suggestions though.
Anything else it could be?
Default 03-07-2010, 07:40 PM
Does F2 now work? Did you reboot after installing?
« 10v Touch Screen Hack Complete | Acronics sort backup of OS X + Win 7 »
