(#4)
| Member Posts: 40 Join Date: Feb 2010 | Still getting too hot, so I hooked up the fan and that took care of it. But now the noise of the fan drives me nuts. I need to find one that turns real slow, or a speed controller. Don't think it needs to move much air. Right now it's sucking air from the 10v. Could be it's better to blow air to it. Anybody has a pointer for a fan speed controller? Should be able to work with 5V. Thanks. |
(#5)
| Super Moderator Posts: 5,686 Join Date: Nov 2008 Location: New Hampshire | Something is wrong with your 10v, then. It should not get hot. Perhaps the thermal pads between the CPU/chipset and palmrest plate are misplaced. Mini 9|2GB RAM|64GB RunCore|Intel 5300|Windows 8 |
(#6)
| Member Posts: 40 Join Date: Feb 2010 | Oh, I wouldn't have thought so after seeing a number of other posts discussing heat problems. I did upgrade to 2GB RAM, but it was getting hot before just the same. Should I send it back to Dell? It's a refurbished unit. I have lots of scrap aluminum laying around and could fashion something if I knew how it should look like. Maybe I should start a new thread. Thanks for the info! Holger |
(#7)
| Super Moderator Posts: 2,706 Join Date: Aug 2009 Location: Upstate New York, U.S of A. | I saved all that trouble and just bought a Targus Netbook Chillpad...works great..does nothing to battery life ![]() ![]() ![]() PS. fits right into my Targus Netbook Case....and NO I dont work for Targus ![]() |
(#8)
| Member Posts: 40 Join Date: Feb 2010 | Quote:
![]() Holger | |
(#9)
| Senior Member Posts: 451 Join Date: Dec 2009 | Quote:
Another way to control temps is use of VooDooPowerMini (get SL version) and CPU-i VoodooPower 1.2.3 - InsanelyMac Forum A fan should not be required. Phil | |
(#10)
![]() Holger | |
| Tags |
| 10v, stand |
