wildfxp wildfxp is offline
Default FIXED = BT problem :( - 02-22-2010, 02:02 AM
*sigh*, I had the bluetooth module added myself just 4 days ago and now it doesn't work anymore.
I had it disabled in Win7, but the option of it was always there when I pressed F2.
I decided to go onto the SL 10.6.2 partition today and noticed the wifi did not work, so stupid me, I re-installed the 10v extensions with netbook installer. I didn't realize that I just had to enable wifi in Win7 for it to work in OSX.
Now the bluetooth option is gone in both partitions and I'm not sure how to re-enable it.
I see threads about it, but nothing for Win7 and SL dual boots.
---------- Post added at 02:02 AM ---------- Previous post was at 01:43 AM ----------
Problem fixed because of this thread
Bluetooth disappeared after XP reinstall?
I tried re-installing the WIFI tray driver for the 10v, but it does not allow reinstalling.
I then kept re-enabling/disabling BT in bios, but did not work as well.
« metal plat as replacement for fan? | New Member -- Just saying hi »
