justjeeeeen justjeeeeen is offline
Default sound buzzes - 02-13-2010, 06:15 AM
i got a refurbished dell mini 10v from the dell outlet a couple weeks back. the first few days the sound worked crystal clear but on like the 3rd day, my sound just started to buzz even when the sound was low kinda annoying if theres a way to fix the buzzing it will be much appreciated =]
Default 02-15-2010, 04:07 PM
Is the buzzing over the onboard speakers? Headphones?
charlesc2010 charlesc2010 is offline
Default 03-20-2010, 01:48 PM
i got the same problem its on the right side of the netbook so I assume its speakers harddrive is on the left side and it sounds fine mines like a screeching noise tho like a tv with no signal
« Just received Refurbished 10v broken LCD frame | Bad Battery or did I do something »
