| Junior Member Posts: 3 Join Date: Dec 2009 | I recently purchased a 10v with N280 and stock 1GB memory. Following the suggestions from these great forums, I went ahead and purchased a 2GB memory stick (CORSAIR DDR2 667MHz VS2GSDS667D2 G) I have downgraded the bios to A05 in order to install Mac OS 10.6.2 using 0.8.3RC5. Lately, I have had several kernel panics. I started by reinstalling the OS, maybe this was related to the build or I don't know. I never really got any clues as to what the panics were pointing to. I would see display artifacts on some of the crashes and even once while bios was loading. I set out to run a memory tester. Kelley Computing - Rember All 3 times I ran this, crash. I have not swapped the 1GB back in yet and will do so soon. But I decided to hit dell support up on this and say I was using Ubuntu. They tell me that this system only supports 1GB of memory. No matter what I said otherwise, or that others are using 2GB fine, they swear that 1GB is the max. (I have seen ubuntu configurations allow 2GB in the past until recently, possible change?) I decided to dig a little, first was the setup doc for the 10v. Connectors one internally-accessible SO-DIMM socket Capacities 512 MB and 1 GB Memory type DDR2-800 (Run @ DDR2-533 MHz) Memory configurations possible 512 MB, 1 GB This would confirm Dell's position on the matter. I then pulled up the Intel Chipset doc. System Memory Support • Supports single-channel DDR2 SDRAM only • Maximum Memory supported 2 GB • Memory Channel Topologies supported: — Single-channel with 1 SO-DIMM only (up to 1 GB) — Single-channel with 1 SO-DIMM (up to 1 GB) and Memory Down (up to 1 GB) • Support for DDR2 at 400 MHz and 533 MHz So what I think based on the documents is that the 10v (1011) is a Single-channel and therefore only able to handle 1GB. I know others are successfully running 2GB so I'm lost. I will still try and get my 2GB stick replaced. I have another stick I'm giving the wife for xmas in her 10v with Win7 but I'm cautious to install it now. Hoping for some help from the great community here. Regards, Brad |
(#4)
(#5)
(#6)
(#7)
| Junior Member Posts: 21 Join Date: Dec 2009 | Quote:
Bob | |
