MEinSoCal MEinSoCal is offline
Question whats the easiest way to project the 10v onto a TV? - 12-23-2009, 05:42 PM
easiest and cheapest way. looks like it'll have to be via SVGA out or USB. suggestions appreciated.
Default 12-23-2009, 06:22 PM
If the TV has a VGA input, then a VGA cable. You can get a VGA to S-Video/composite converter, but the quality tends to be poor. If you find something that claims to be a cable that goes from VGA to S-Video, it won't work on the Mini.
tv out
« Mini 10v SSD Question | Going from OS X back to XP »
