Default Hard Drive, Memory, Fan Questions - 12-13-2009, 02:38 PM
Hey Guys,
I just recently bought myself a mini 10v and I have a few questions about the Hardware on the Mini 10v:
1. Does the brand of the Hard drive matter when I'm replacing it?
2. Does the brand of the Memory matter when I'm replacing it?
3. Is there even a fan on the Mini 10v? Will the computer overheat if you replace the hardware and run really intensive programs?
Thanks so much.
Default 12-13-2009, 03:09 PM
1. No, as long as the specs are compatible (SATA, right form factor)
2. Same as #1 (DDR2, SODIMM, 533MHz or faster, no larger than 2GB)
3. No fan. It won't overheat if you don't block the cooling vents, but may get pretty warm. It has built-in protection against overheating (it will slow down if too hot.)
Cool 12-13-2009, 03:11 PM
Originally Posted by Warnerweilin View Post
Hey Guys,
Thanks so much.
1. no the brand really doesnt matter, but it must be a 2.5inch SATA drive, whether or not its an HDD or a SSD..is up to you..I prefer the HDD, I replaced mine with a 500gb..(HDD is Hard Disk Drive, SSD is Solid State Drive ie. no moving parts)
2. do a search on the forum there are some recommendations..533mhz or faster..machine will accept faster but not utilize it..and a 2gb max
3. the Mini 10 nor the Mini 10v have fans..I purchased a netbook cooling pad for mine. and yes they do tend to run very warm...some even say hot, depending on the hard drive and actitvity, a 7200rpm drive will generate more heat than a 5400rpm drive..of course this doesnt apply to SSD drives...
Good Luck with your purchase..and Welcome to the Forum..feel free to ask questions
fan, hard drive, memory, ram upgrade
« Windows 7 Touch Pad Driver | question about dell mini 10v »
