(#11)
(#12)
(#13)
| Super Moderator Posts: 871 Join Date: Aug 2009 Location: Herefordshire (U.K.) | Hi Mr Singh, I am pleased to hear that it is on its way already... are the full tracking links working OK now, as they weren't before? I did in fact post a thread about this some while ago, but it may not now be needed... but, just in case, here it is anyway: Dell Order Tracking Problems (U.K.) My post #5 in that thread shows the UK delivery procedure, (unless they have changed it since then, which I doubt!) so I would have thought that you should be receiving that call soon. I have Windows 7 loaded on mine, so am not going to be any help to you at all with OS X, but there is a separate area of the forum covering this, where you will find loads of helpful advice. Anyway... so far, so good! ![]() |
(#14)
| Member Posts: 59 Join Date: Nov 2009 Location: Berkshire, UK | ![]() Thanks Montala - it wasn't working but via your instructions - it's working perfectly! MUCH appreciated! I got it wrong - it's coming from China. I guess the packing list/receipt is generated in 'Limerick' which confused me a little - doesn't take much to do that! Once agin, thanks - very helpful forum this. ---------- Post added at 05:31 PM ---------- Previous post was at 04:51 PM ---------- Having a few probs though..... Can I boot via a Compact Flash Card? > MacPro - 2.8GHz / 8 Cores - Various HD's - 8Gb RAM - OS X 10.6.6 |
