| Junior Member Posts: 23 Join Date: Nov 2009 | Hi all, I just got my Dell mini 10v with the 1510 wireless card. The wireless internet would not connect until several tries later, but then it was on and off, constantly disconnecting until it finally stopped working. I began to install Mac OS X SL, and again the wireless took several tries to connect. The speed was then super slow, and I am now confident that there is a loose connection inside after reading this thread: Mini 10v - Network Problem - Slow Connection - WiFi Timeout However, I have no idea where the wireless card is and how to take it apart, and what to do if it is loose? Thanks! |
(#4)
(#5)
(#6)
(#7)
| Senior Member Posts: 423 Join Date: Sep 2009 | I am betting it is your router that is the problem (configuration/settings). What type do you have? NBI 8.2 -> NBI 8.3RC2 -> NBI 8.3RC3 -> NBI 8.3RC5 -> NBI 8.3 alpha USB Legacy Disabled | USB Wake Enabled | BT Enabled | www.suckerpunchent.com |
(#8)
(#9)
(#10)
| Junior Member Posts: 23 Join Date: Nov 2009 | Quote:
Dell Mini 10v | Obsidan Black | 1.66Ghz Intel Atom | 1GB RAM | 1510 Wireless-N card | Mac OS X SL 10.6.2 | |
