superjon027 superjon027 is offline
Default Power Supply for Mini 10v/9 - 10-29-2009, 05:41 AM
Hi guys,
I know that the power supply is the same for the mini 10v and the mini 9. I was wondering if you guys know where i can purchase one. Doesnt have to be Dell brand. I just need a 2nd one for convenience. I saw one for 12, but the 10 dollar shipping killed it. Any recommendations?
MikePA MikePA is offline
Default 10-29-2009, 08:29 AM
Bought mine on eBay.
Mini 9 | 2 gigs memory | 64 gig SSD | 10.6.7
Mini 10v | 2 gigs memory | 500 gig HD | BT | 10.6.3 & Windows 7 Professional Dual Boot
mattkime mattkime is offline
Default 10-29-2009, 12:48 PM
lancorp lancorp is offline
Default 10-31-2009, 11:42 PM
The problem with those Kensington units is that there is not a tip that fits perfectly on the 10v. I've been using these Kensingtons for years, and have a stockpile of extra tips and have tried them all. N3 fits the best, but doesn't always make a connection. If you leave it perfectly still while charging then you're ok, but if you move it it loses the connection.
Let us know if you find a tip that works with the 10v.
Default 11-01-2009, 05:40 PM
I believe I'm using the N3 tip without trouble. maybe i'm just lucky.
Cool 11-01-2009, 06:32 PM
did you check the buy/sell forum on this board?
Default 11-01-2009, 07:18 PM
Also just FYI, the 1010 uses the same PS too, I'm running my 1010 now on my 910 PS.
« no sound after 2gb ram upgrade | Dell Wireless 1510 driver for Windows 7 »
