(#4)
(#5)
| Senior Member Posts: 121 Join Date: Sep 2009 | My 10v came with a Seagate Momentus 160GB 5400rpm drive ST9160314AS Momentus 5400.6 SATA 3Gb/s 160-GB Hard Drive | Seagate So the WD Scorpio Black 7200 drives outperform the current one I have? I just don't want to spend like R600 ($80) if I wont notice any difference. |
(#6)
| Member Posts: 59 Join Date: Jul 2009 | I would not use such a fast drive because it needs more power and makes the Netbook warmer. May you will have in Afrika then more Problems with temperature Issues. Also the Laptop is not performat enough to load the data faster as from a 5400 rpm drive. So wait until the price for flash will drop and then you can switch. Greetings from the Black Forrest. Starmanager |
(#7)
(#8)
| Senior Member Posts: 298 Join Date: Sep 2009 Location: Modding minis - where else? ;) | I did the upgrade in RAM and the HD at the same time. It felt more responsive after (as it should), but I don't know if it's the RAM or HD. SSDs are nice - they feel more responsive (maybe it's just the lighter wallet talking ). More importantly, they'll run cooler (with that 2gb, you'll want to keep a lid on heat as much as possible). |
(#9)
| Super Moderator Posts: 1,203 Join Date: Apr 2009 Location: Detroit | The 7200 rpm drives are faster (seat of the pants test), but they do consume more power, and they spin faster. Spinning faster generally means a little noisier. I put a WD Scorpio Black in mine, and it was too noisy and caused too much vibration. When I got my new one, I put a WD Scorpio Blue in, and much much much better.. Triple Boot Guide - 10v RAM Upgrade Videos - mechdrew's OSX guides |
(#10)
