danwan danwan is offline
Default Mini 10v OSX86 Ethernet card problem - 10-20-2009, 06:35 PM
I used the Dell Mini10v with OSX86 and everything works fine except my ethernet connection. I am unable to use. Although the cable works with my regular Macs I receive an error message every time I try to connect to the internet.
Everything works including Wifi which seems to be a lot better than my mac as it reads the signal from a very far room however the connection is slow and I hope to be able to connect through my router.
I installed a Retail Snow leo removing the internal hard disk and following the guide it worked very well ....
Another issue though is I am never able to repair my permission as Disk Utiliy tells me there are no persmission files in my system .... how to solve this?
hotrodminis's Avatar
Default 10-20-2009, 09:57 PM
You may have faulty hardware.
« Windows 7 install requires driver on 10v? | Dell 1011 + OSX SL + HDMI output »
