omgcorey omgcorey is offline
Default 10v webcam problems? - 10-13-2009, 10:38 PM
I'm using windows 7 on my dell mini and everything on my cam was working fine. Used it on aim once and it worked fine. Now when I try to use it on Aim, it just shows a black screen...?
I'm not really sure what the problem is, whether it be the cam went bad or if it's me doing something wrong.
What can I do to see if the cam isn't broke or to make sure that it is atleast working? I would just like to get it to work on AIM for when I talk to my gf.
Mini 10v
N280 | 160gB HDD | 1gB RAM | 6 Cell | 1397 WiFi
dj898 dj898 is offline
Default 10-14-2009, 10:56 PM
I'd like to know too. In my case I never could get it work under Windows 7 RTM...
Bear Hunter Bear Hunter is offline
Bear Hunter's Avatar
Default 10-14-2009, 11:58 PM
Is your cam not showing up in "Control Panel"? I'm no windows guy, but I would expect it to be there, and you should be able to double click to open it up and see if it works.
Dell Mini 10v Mac OSX 10.6.2 1 GB RAM 160GB HDD BIOS A05 Blue Tooth 1510 WLAN 802.11g /n
NBI 8.2 -> NBI 8.3RC2 -> NBI 8.3RC3 -> NBI 8.3RC5 -> NBI 8.3 alpha
USB Legacy Disabled | USB Wake Enabled | BT Enabled |
« Upgrade to Windows 7? | Reload this Page Multi Channel Audio on 10v with onboard sound card »
