MiniKar2n MiniKar2n is offline
Default Problems: 1510 wifi card not working - 10v with OSX SL 10.6 - 09-22-2009, 04:14 AM
I have 2 - 10v systems. One has a 1397 wifi card and the other has a 1510 wifi card. Both worked fine with OSX 10.5.8. However, only the one with a 1397 card works with OSX SL 10.6 and 10.6.1.
The other 10v with the 1510 would not work on my first install of SL 10.6. I had to downgrade to 10.5.8.
Before i re-install using Netbookinstall .8.2 with the SL 10.6 disc, i would like to hear from others that have successfully used Netbookinstall .8.2 & SL 10.6 on their 10v with a 1510 wifi card.
Thank you much for your feedback.
Max_Carnage Max_Carnage is offline
Default 09-22-2009, 08:11 AM
I have a 10v with 1510 wireless.
It worked fine with OS 10.6.0 and NBI 0.8.2.
I did have trouble at one point with it not working reliably after sleep but fixed it with a combination of BIOS settings and re-running the dsdt.aml generator (don't know which was the fix as I tried both at the same time).
It works fine with OS 10.6.1 and NBI 0.8.3.
Dell Mini 10v | OSX 10.6.1 | 2GB RAM | 160GB HDD | 1510 Wifi | BIOS A04 | USB Legacy: OFF | USB Wake: ON | OEM BT 2.0: ON | NetbookInstaller 0.8.3 RC3
Status: A little slow to boot. Otherwise perfect!
DMBryant DMBryant is offline
DMBryant's Avatar
Default 09-22-2009, 10:02 AM
I have a 1510 wireless card and 10.6.1 (using NBI 0.8.2) and it works perfectly all the time. No issues at all.
Mini 10v | 2GB RAM | 120GB HDD | 1510 N Wireless | BT 2.1 | OSX 10.6.4 | NBI 0.8.4RC1 | Bios A04 | 1010 Touchpad | Magic Mouse
Default thanx for the feedback - 09-23-2009, 02:46 PM
Looks like a case for operator error on my part. Will reload after 8.3 testing is finished. Thanx for the feedback.
« Got my mini 10v today | Moblin powered 10v Announced »
