| Member Posts: 44 Join Date: Apr 2009 Location: St. Petersburg, FL | Quote:
But, in a nutshell, after installing the VoodooHTA via KextHelper 1) Download and install SleepWatcher: Download SleepWatcher for Mac - Execute commands when sleeping or awakening. MacUpdate Mac System Software Downloads (install both packages) 2) Open up the Terminal app (in utilities) 3) Code: cd /etc Code: sudo vi rc.wakeup 5) Hold the Shift Button and press GG (this will bring u to the bottom of the file) 6) Quickly, press the Esc and i button (it should show --insert--) 7) Copy and paste the following to the end of the file: /sbin/kextunload /System/Library/Extensions/VoodooHDA.kext>>/var/log/system.log /sbin/kextunload /System/Library/Extensions/VoodooHDA.kext>>/var/log/system.log /sbin/kextunload /System/Library/Extensions/VoodooHDA.kext>>/var/log/system.log /sbin/kextunload /System/Library/Extensions/VoodooHDA.kext>>/var/log/system.log sleep 3 /sbin/kextload /System/Library/Extensions/VoodooHDA.kext>>/var/log/system.log /sbin/kextload /System/Library/Extensions/VoodooHDA.kext>>/var/log/system.log /sbin/kextload /System/Library/Extensions/VoodooHDA.kext>>/var/log/system.log /sbin/kextload /System/Library/Extensions/VoodooHDA.kext>>/var/log/system.log 8) Press Esc twice and the --insert-- should be removed 9) Now press Shift : 10) Type wq 11) Press enter You're done | |
(#4)
(#5)
(#6)
(#7)
| Member Posts: 62 Join Date: Jun 2009 | Solved it... Thanks for the help. I had to type in something like "vim -r rc.wakeup" to recover the file, then delete the backup, then I edited the file, and pasted your in there and so far so good! Thanks again mate. Get yourself a real MacBook with Lockerz! I got invites! PM me. ![]() |
(#8)
| Junior Member Posts: 17 Join Date: Jul 2009 | Hi all I tried rhis on my son's Mini 10V with the following result: As he's only 10 he has a standard account with parental controls. I logged in as admin on my account and followed the instructions, all seemed to work OK but it does not work on his account. My admin account works great. How can I make it work in his account? The idea I had was to change his account to admin, make the changes then change it back to standard, but as I'm not a wiz in the guts of the OS, I'm not sure if the changes I already made mean that I can't do the same operation in his account or not. Any help greatly appreciated and many thanks for the crackle fix! |
(#9)
Code: sudo chmod 777 /etc/rc.wakeup Mini 10v - Atom 1.6 - 1 GB RAM - 16GB SSD - 1.3 Camera - Obsidian Black - OSX 10.6.1 Mini 9 - Atom 1.6 - 1 GB RAM - 16GB SSD - 1.3 Camera - Obsidian Black - OSX 10.5.8 Vostro A90 - Atom 1.6 - 1 GB RAM - 16GB SSD - .30 Camera - BT - Obsidian Black - OSX 10.5.8 | |
(#10)
| Tags |
| 10v, kext, rc.wakeup, script, voodoohda |
« 10v OS X Success... thanks mydellmini!
Help me repeat what I did by accident, Display Settings »
