  (#81) Old
MidTownHD's Avatar
Default 06-01-2009, 02:19 AM
I thought the graphics in Mini10 wasn't compatible with Mac OS X...
  (#82) Old
somms's Avatar
Default 06-01-2009, 02:57 AM
Mini 1011 (Mini10v) is completely diff than Mini 1010 (Mini10)
  (#83) Old
Default 06-01-2009, 03:01 AM
when i get to the Installer window, my resolution is too low. I cannot see or click on the Continue button. Dell EFI v.1.1 method. Any thoughts?
  (#84) Old
Send a message via AIM to Carlos Send a message via Yahoo to Carlos
Default 06-01-2009, 03:09 AM
Try hitting enter. Or hitting tab, then enter.
  (#85) Old
Default Extra Monitor - 06-01-2009, 08:40 AM
Hi, I just joined the forum. I've been reading a whole lot of this information for the better part of a week and I'm incredibly intrigued. I'm about to take the plunge on trying to make a Hackintosh, but I'm undecided on which model to get (Mini 9 or Mini 10v). I really kind of like that the Mini 10v has the 120gig HD because I'd love to dual boot Win 7 and OSX. I really appreciate all the hard work and info you're all sharing. I just have a few questions:
1. Do you have a personal recommendation on one of the mini 9's that are left or should I go mini 10v, or does it matter that much?
2. With the mini 10v, what's the status on using it with an external monitor. Do we have confirmation that it works (usefully)?
3. Am I correct in understanding that with the exception of the additional sound drivers that need to be installed, a mini 10v hackintosh works essentially the same way as mini 9 hackintosh and works the same as well? Is there any appreciable difference?
4. Do I understand that both the base wireless-g and the upgraded wireless-n cards both work?
Thanks so much!
  (#86) Old
infodroid's Avatar
Default 06-01-2009, 10:41 AM
Originally Posted by anguish View Post
EDIT 3: Sound does work. Use this link: http://www.blackmonktech.com/NC10%20...ackage.pkg.zip Install it, reboot, should be golden.
I wouldn't use this package. It installs a lot of NC10 specific kexts to /S/L/E which you don't really want on a Mini 10v as they are already covered by DellEFI and you will no longer have a vanilla OSX.
Quicksilver and some scripts for altering the brightness on a NC10 are installed as well.
The only kext you need should be the AppleHDA.kext from the package.
AppleHDA.zip
Mini 9 Black | 2 GB RAM | 16 GB Stock Dell SSD | BT | 1.3MP Cam | OSX 10.5.7 | DellEFI 1.2a5 | BIOS A04
  (#87) Old
lugesm's Avatar
Default 06-01-2009, 12:58 PM
AppleHDA.zip
This sounds important.
I downloaded it, and it unzips as a .kext file. I have no 10v yet, so can't comment on the actual use of this kext.
1. Have you used used this on a Mini 10v yet? Results ?
2. I suspect that many members here do not know what to do with a raw .kext file.
It would be very helpful if you could elaborate a little on your experience with the file and how you applied it.
Thanks,
Dell Mini10v, 64GB RunCore Pro IV SATA SSD, 2GB Memory, A06 BIOS, 10.6.7, NBI 20100616212351, Bluetooth enabled (external dongle), USB Legacy disabled.
  (#88) Old
anguish's Avatar
Default 06-01-2009, 01:16 PM
If just that kext works, then that's beautiful. Unfortunately, I'm still learning OS X, so I have no clue how to extract that file that I linked to. I'll leave it for now until someone confirms, then I will change my first post.
  (#89) Old
infodroid's Avatar
Default 06-01-2009, 01:59 PM
I forgot to mention that I extracted the kext from the NC10 package.
Unfortunately I don't have a 10v yet. I'm still arguing with me if I could life with the lesser resolution and the shorter battery life (the 6 cell hunchback is not an option for me).
I'm beginning to suspect this as well.
The easiest way would be Kext Helper. Never used it myself I'm more a Terminal type of guy.
Kext Helper b7
It would be best if bmaltais could integrate it into DellEFI. I read somewhere that there's a plan to integrate a hardware recognition to install the right kexts. So it should be in the works.
If you want more to know about installing kexts or hackintoshing in general, InsanelyMac Forum is a great resource for that.
  (#90) Old
meklort's Avatar
Default 06-01-2009, 03:15 PM
I've already added that kext into DellEFI 1.2a6. Once I'm finished it up a bit, I'll release the new changes. It does detect which device it's being installed on, so if someone could give tell my what "sysctl hw.model" output's in the terminal as well as a copy of kextstat output when everything is working, that would be very helpful.
Posted By For Type Date
