  (#541) Old
Default 11-22-2009, 03:31 PM
Originally Posted by altazor51 View Post
Hi,
I have this weird eject button/symbol next to time and wifi bars on the upper right of my screen. when i click on it, it says no drives. could this have anything to do with it?
thank you all, i couldn't have come this far without all your detailed input...
Stick a USB stick in - if it mounts you should have it listed under the eject button. Or plug in an external DVD drive perhaps...
  (#542) Old
Default 12-02-2009, 08:17 AM
It doesn't work - it always says no drives.
  (#543) Old
Default 12-02-2009, 12:04 PM
I always remove the eject button so I'm not sure but...
Try mounting a disk image, i.e. double click a .dmg file and see if the eject button will work for that for you.
Mini1: Vostro A90, Black, 2G, 1.3 Webcam, Bluetooth, 64G SuperTalent, OS X 10.5.8
Mini3: Mini10v. Black, 2G, Webcam, 500G HD, OS X 10.5.8 [Hibernate w/NBI 0.8.3 RC4]
Dropbox Referral
  (#544) Old
Default 12-21-2009, 08:19 PM
I'm on 10.6.2 and restart won't work after sleep. The screen goes black but the LED light indicates that the machine is still running. The only way out is a hard reset (keep the power button pressed until it completly shuts down)
Has anyone else experienced this, is there a fix?
edit: NBI 8.3 RC5 worked! I am now rebooting successfully after sleep.
Cheers
PS: I have the permanent eject button too. It does not show thumb drives nor dmg disk image files. Doesn't really bother me though.
  (#545) Old
Default Remove Eject Button from Menubar - 12-21-2009, 11:56 PM
Hold down command key and drag the eject button from the menubar to the desktop with the mouse.
If you want it back it is in the CoreServices folder in the system's library.
Hope this helps.
Cheers
m
  (#546) Old
Bear Hunter's Avatar
Default 12-22-2009, 12:11 AM
I can also confirm that the eject button always shows no drives...it doesn't matter what kind it is.
Dell Mini 10v Mac OSX 10.6.2 1 GB RAM 160GB HDD BIOS A05 Blue Tooth 1510 WLAN 802.11g /n
NBI 8.2 -> NBI 8.3RC2 -> NBI 8.3RC3 -> NBI 8.3RC5 -> NBI 8.3 alpha
USB Legacy Disabled | USB Wake Enabled | BT Enabled |
www.suckerpunchent.com
  (#547) Old
Default 01-29-2010, 02:51 AM
You guys are insane. I can't thank you guys enough.
  (#548) Old
Default 03-03-2010, 06:52 AM
Good morning. I am completely lost. I want to buy a Dell in order to install Mac OSX an I don't know if Dell mini 10v, or Dell mini 1011 is the right one. Or maybe the two models are the same ? Looking in the market in order to understand what is the difference between them and can't figure out. Can somebody clarify that ? Regards
  (#549) Old
DMBryant's Avatar
Default 03-03-2010, 09:13 AM
Dell Mini 10v and 1011 are the same thing. 10v is the commercial name for it and 1011 is the Dell model number.
Mini 10v | 2GB RAM | 120GB HDD | 1510 N Wireless | BT 2.1 | OSX 10.6.3 | NBI 0.8.4RC1 | Bios A04 | 1010 Touchpad | Magic Mouse
  (#550) Old
Wink 03-03-2010, 10:37 PM
THNX for the answer
Posted By For Type Date
Mini 10v OS X UPDATED for AUDIO! - These guys... - Jan Ole Peek - FriendFeed This thread Refback 10-03-2009 09:32 AM
permafrown's Bookmarks on Delicious This thread Refback 09-03-2009 07:38 AM
Dell Mini 10 and 10v netbooks now available in Dell Outlet Home - 15% off coupon code via e-mail UNDER 200 SHIPPED! - SlickDeals.net Forums This thread Refback 09-02-2009 10:06 PM
toddje's Network on Delicious This thread Refback 09-01-2009 02:50 PM
???????? : Macintosh This thread Refback 08-29-2009 08:54 AM
???????? This thread Refback 08-29-2009 02:05 AM
Mac fans This thread Refback 08-25-2009 09:14 PM
The State of Hackintosh: Which Netbooks to Hack [Hackintosh] - Nibbet.com This thread Refback 08-25-2009 01:59 PM
1:1 Moving at the Speed of Creativity This thread Refback 08-24-2009 10:14 PM
Dell Mini 10v | Austin Kim This thread Refback 08-24-2009 08:01 PM
Mini 1011 (Mini 10v) and OS X - Info - UPDATED for AUDIO!!!! This thread Refback 08-24-2009 01:19 PM
???????? ????? - blog:N@TURE BRAIN This thread Refback 08-24-2009 03:54 AM
The State of Hackintosh: Which Netbooks to Hack [Hackintosh] This thread Refback 08-21-2009 05:59 PM
osx - Jochen Lillich on Diigo This thread Refback 08-19-2009 06:53 PM
The State of Hackintosh: Which Netbooks to Hack [Hackintosh] - Striker Techo Feeder (RSS) This thread Refback 08-19-2009 12:51 AM
Hcl - Muzzle.nl This thread Refback 08-18-2009 05:48 PM
dell | Eee PC - Blog - Part 2 This thread Refback 08-13-2009 09:30 AM
My Dell Mini 10V Netbook with Ubuntu is on the way Moving at the Speed of Creativity This thread Pingback 08-12-2009 04:31 PM
Jan Ole Peek - Comments This thread Refback 08-11-2009 03:29 PM
Mini 1011 (Mini 10v) and OS X - Info - UPDATED for AUDIO!!!! - Page 45 This thread Refback 08-10-2009 05:35 PM
Randomness lenovo s10-2 This thread Refback 08-09-2009 01:01 AM
Wikipedia This thread Refback 08-08-2009 05:56 AM
calmahomer's Bookmarks on Delicious This thread Refback 08-07-2009 06:44 PM
Updated Hackintosh Compatibility Chart -:: Malaysia Mobile Tech News ::- This thread Refback 08-07-2009 10:18 AM
livedoor ???? - ?????????????????????? This thread Refback 08-06-2009 01:46 PM
RSS fabriek os x This thread Refback 08-06-2009 06:45 AM
CHW Los mejores netbooks para instalar Mac OS X This thread Refback 08-05-2009 08:44 AM
?????????????????????? : Gizmodo Japan????????????, ???????????? This thread Refback 08-04-2009 12:20 PM
Randomness Dell mini 10v This thread Refback 08-01-2009 12:21 PM
???????? : MacBook mini This thread Refback 07-31-2009 09:01 PM
ciaconne's Bookmarks on Delicious This thread Refback 07-31-2009 01:31 PM
The State of Hackintosh: Which Netbooks to Hack [Hackintosh] | NewsCred, Quality Newspapers & Blogs This thread Refback 07-31-2009 12:46 PM
The State Of Hackintosh: Which Netbooks To Hack | Gizmodo Australia This thread Refback 07-31-2009 12:41 AM
Gizmodo - The State of Hackintosh: Which Netbooks to Hack This thread Refback 07-30-2009 11:03 PM
The State of Hackintosh: Which Netbooks to Hack - Mac os x netbook chart - Gizmodo This thread Refback 07-30-2009 06:08 PM
Untitled document This thread Refback 07-30-2009 08:58 AM
MacOSX86̖낤!24 This thread Refback 07-29-2009 11:25 AM
Dell Mini 10 and 10v netbooks now available in Dell Outlet Home - 15% off coupon code via e-mail UNDER 200 SHIPPED! - SlickDeals.net Forums This thread Refback 07-28-2009 04:50 PM
Hackintosh-Erfahrungsbericht zum Dell Mini 9 mit Mac OS X 10.5.7 [Update] - macboard.ch This thread Refback 07-27-2009 08:44 AM
Dell Mini 10v Hackintosh Underway This thread Refback 07-25-2009 10:47 AM
Dell Mini 10 and 10v netbooks now available in Dell Outlet Home - 15% off coupon code UNDER 200 SHIPPED! - SlickDeals.net Forums This thread Refback 07-24-2009 09:11 PM
Dell Mini 10v netbook now available in Dell Outlet Home - 15% off coupon code via e-mail UNDER 200 SHIPPED! - SlickDeals.net Forums This thread Refback 07-23-2009 09:07 PM
Dell Mini 10v netbook now available in Dell Outlet Home - 15% off coupon code via e-mail UNDER 200 SHIPPED! - SlickDeals.net Forums This thread Refback 07-23-2009 02:07 PM
Netbook Review UK | Netbook and Mini-Laptop Reviews, Comparisons and News - Part 16 This thread Refback 07-22-2009 11:40 PM
j.lane's Bookmarks on Delicious This thread Refback 07-21-2009 06:34 PM
Dell Mini 10vで - blog:N@TURE BRAIN This thread Refback 07-21-2009 12:09 AM
Dell Mini9: Did I completely miss the boat on this? This thread Refback 07-20-2009 04:55 PM
Dell Mini 10v netbook now available in Dell Outlet Home - 15% off coupon code UNDER 200 SHIPPED! - SlickDeals.net Forums This thread Refback 07-19-2009 03:37 PM
Dell Outlet Mini 10 and Mini 10v 15% off - New coupon code This thread Refback 07-18-2009 12:29 AM
Dell Mini 10v netbook now available in Dell Outlet Home - 15% off coupon code UNDER 200 SHIPPED! - SlickDeals.net Forums This thread Refback 07-17-2009 09:06 PM
はてなブックマーク - caminoroad のブックマーク This thread Refback 07-15-2009 04:02 PM
Dell Mini 10v netbook now available in Dell Outlet Home - SlickDeals.net Forums This thread Refback 07-13-2009 08:32 PM
Dell Mini 10v netbook now available in Dell Outlet Home - 15% Coupon Code - UNDER $200 shipped! - SlickDeals.net Forums This thread Refback 07-12-2009 03:38 AM
Dell Inspiron Mini 10 (10v): Hackintosh - gdgt This thread Refback 07-10-2009 03:57 PM
MyDellMini | Site profile | BoardReader This thread Refback 07-10-2009 01:02 PM
Dell Mini 10v netbook now available in Dell Outlet Home - 15% Coupon Code - UNDER $200 shipped! - SlickDeals.net Forums This thread Refback 07-10-2009 12:25 PM
Dell Mini 10v netbook now available in Dell Outlet Home - 15% Coupon Code - SlickDeals.net Forums This thread Refback 07-10-2009 03:31 AM
Dell Mini 10v netbook now available in Dell Outlet Home - 15% Coupon Code - SlickDeals.net Forums This thread Refback 07-10-2009 01:57 AM
Dell Mini 10v now available in Dell Outlet Home - 15% Coupon Code - SlickDeals.net Forums This thread Refback 07-09-2009 09:01 PM
Mini 1011 (Mini 10v) and OS X - Info - Page 11 - MyDellMini This thread Refback 07-08-2009 04:28 PM
DELL MINI10ΰװ10.5.6 - Mac OS X -[Leopardۺ] - Mac OS X For PC (X86) - Զ̳ - ǵϵͳ̳|Windows 7,Windows Vista,Windows XP,Mac OS X This thread Refback 07-08-2009 07:47 AM
os x Diet Recipes Free This thread Refback 07-07-2009 11:43 PM
Foros Cantv.net: NUEVA MINI SIRAGON ATHOM 1.6 GHZ This thread Refback 07-05-2009 01:34 AM
.mac.ro - Your site for news around planet .mac - Immer die aktuellsten Nachrichten und Meldungen. This thread Refback 07-02-2009 08:59 AM
Dell Mini 10v now available in Dell Outlet Home! - SlickDeals.net Forums This thread Refback 06-30-2009 01:40 PM
Dell Mini 10v now available in Dell Outlet Home! - SlickDeals.net Forums This thread Refback 06-30-2009 03:23 AM
whalespine.org This thread Refback 06-29-2009 10:44 PM
Mini 1011 (Mini 10v) and OS X - Info - MyDellMini - mtakeshi - FriendFeed This thread Refback 06-28-2009 12:26 PM
ڹΥ֥ : Boot123 This thread Refback 06-28-2009 04:53 AM
Mini 1011 (Mini 10v) and OS X - Info - MyDellMini This thread Refback 06-27-2009 11:27 PM
Topic: hackintosh - MyBlogLog This thread Refback 06-26-2009 11:25 PM
EEE PC - The unofficial blog about Asus Eee PC - Part 9 This thread Refback 06-24-2009 10:04 AM
Jason Fitzpatrick's Messages This thread Refback 06-23-2009 01:03 PM
Jan Ole Peek - FriendFeed This thread Refback 06-23-2009 05:43 AM
Competitor | Eee PC - Blog - Part 3 This thread Refback 06-22-2009 08:48 PM
DELL MINI10ΰװ10.5.6 - Mac OS X -[Leopardۺ] - Mac OS X For PC (X86) - Զ̳ - ǵϵͳ̳ Windows 7,Windows Vista,Windows XP,Mac OS X This thread Refback 06-21-2009 03:08 AM
MacOSX86̖낤!24 This thread Refback 06-21-2009 02:53 AM
studioda blog : DELL Mini10 - MacOS DVD 起動せず... This thread Refback 06-17-2009 10:58 AM
alexander.platz's Bookmarks on Delicious This thread Refback 06-17-2009 08:00 AM
ڹΥ֥ This thread Refback 06-12-2009 10:59 AM
ڹΥ֥ : 2009ǯ06 This thread Refback 06-12-2009 08:12 AM
johaneje's Bookmarks on Delicious This thread Refback 06-12-2009 07:19 AM
lostgweilo's Bookmarks on Delicious This thread Refback 06-12-2009 04:35 AM
douglasgraves's dell Bookmarks on Delicious This thread Refback 06-11-2009 04:21 AM
EEE PC - The unofficial blog about Asus Eee PC - Part 4 This thread Refback 06-10-2009 05:21 PM
Liliputing Compact Computing This thread Refback 06-10-2009 03:52 PM
os x This thread Refback 06-09-2009 10:41 PM
Wikipedia This thread Refback 06-08-2009 03:22 AM
jevaun's Bookmarks on Delicious This thread Refback 06-07-2009 02:43 AM
dotMb -Web for Macbook Users and future Macbook Users- This thread Refback 06-06-2009 02:57 AM
ڹΥ֥ : Macintosh This thread Refback 06-05-2009 04:21 PM
Liliputing Compact Computing This thread Refback 06-05-2009 06:50 AM
Dell | Eee PC - Blog This thread Refback 06-04-2009 10:59 PM
RedFlagDeals.com Forums - Comp Dell mini 10v starting $329 This thread Refback 06-04-2009 04:31 AM
mobileMacs Blog Archive MM028 am nchsten Mittwoch This thread Refback 06-03-2009 02:06 PM
10-inch | Eee PC - Blog This thread Refback 06-03-2009 10:25 AM
ڹΥ֥ : MacBook mini This thread Refback 06-03-2009 05:31 AM
ڹΥ֥ : Dell Mini 10ǤMacOSX Leopard ưԤ줿褦Ǥ This thread Refback 06-03-2009 12:39 AM
Accelerate Your Mac News Archive for Monday June 1, 2009 This thread Refback 06-02-2009 08:41 PM
Accelerate Your Macintosh! News Page - 6/2/09 This thread Refback 06-02-2009 07:15 PM
Mac OS X Netbook Compatibility Chart (Updated June 2009: Dell Mini 10v) | Boing Boing Gadgets This thread Refback 06-02-2009 03:22 PM
[Comp] Dell mini 10v starting $329 - Page 4 - RedFlagDeals.com Forums This thread Refback 06-02-2009 03:01 PM
Liliputing Compact Computing This thread Refback 06-02-2009 02:53 PM
Dell Mini 10v | Eee PC - Blog This thread Refback 06-01-2009 11:18 PM
dell inspiron mini 10v This thread Refback 06-01-2009 03:55 PM
Dell Mini 10v: the cheapest Mac ever? - mirror.co.uk This thread Refback 06-01-2009 02:24 PM
Dell Inspiron Mini 10v loaded with Mac OS X | GadgetMix.com!::.. This thread Refback 06-01-2009 01:36 PM
Dell Mini 10v: the cheapest Mac ever? | ElectricPig.co.uk This thread Refback 06-01-2009 01:34 PM
Innocents & Mortals This thread Refback 06-01-2009 08:53 AM
Dell Inspiron Mini 10v, Hackintosh edition with OSX | Netbook Review UK - Netbook Reviews, Compare Netbooks and Netbook News This thread Pingback 06-01-2009 07:51 AM
Dell Mini 10v Running OS X | Eee PC - Blog This thread Pingback 05-31-2009 11:08 PM
hackintosh This thread Refback 05-31-2009 06:55 PM
Dell Inspiron Mini 10v unboxed, loaded with OS X This thread Refback 05-31-2009 04:18 PM
Liliputing Compact Computing This thread Refback 05-31-2009 04:07 PM
11.6 Acer Aspire One AO751h US Preorders Up - Portable Monkey This thread Refback 05-31-2009 12:53 PM
Explore tags on Delicious This thread Refback 05-31-2009 05:06 AM
Dell mini 9 OSX How-to & Discussion: You got Apple in my Dell - The Something Awful Forums This thread Refback 05-30-2009 10:47 PM
fscklog: Hackintosh-Erfahrungsbericht zum Dell Mini 9 mit Mac OS X 10.5.7 [Update] This thread Refback 05-30-2009 03:59 PM
Dell Phasing Out Dell Mini 12 in July? - Portable Monkey This thread Refback 05-30-2009 10:05 AM
Dell Mini 10v Hackintosh Underway - Portable Monkey This thread Refback 05-30-2009 09:27 AM
Portable Monkey This thread Refback 05-30-2009 09:10 AM
UMPC Topsites
