  (#521) Old
anguish's Avatar
Default 09-04-2009, 12:53 PM
I've noticed that as well. You can go in and format the partition though. The issue I ran into last night though (and now this morning) was that I was having issues getting my dualboot to work. I'm trying again right now.
  (#522) Old
Default 09-04-2009, 04:44 PM
I can also format the partition, both from the command line, or from within the W7 setup. Either way, the disk itself is still GPT, so it won't let me install. Have you found a way around that, or were you just agreeing with me? Sorry if I misunderstood.
  (#523) Old
anguish's Avatar
Default 09-04-2009, 04:48 PM
Kinda both. I have been able to format, but also install. I'm using the method I've always used though: do a bunch of prep work via command line from the W7 install media, install OS X, install Windows 7, then install the boot loaders and stuff for OS X.
  (#524) Old
Default 09-05-2009, 11:44 PM
Originally Posted by MacG View Post
I have the same problem with my 10v. 10.5.8 upgrade with Netbookinstaller 0.8.2 and now now QE.
I tried the following but it still didn't work:
Enable Quartz Extreme and Quartz 2D Extreme - AwkwardTV
thanks...Lee
I tried the same thing.... no dice....... it looks like osx isnt using the windowserver.plist..... its using the extension Kexts.......
Update:
So install DellEFI 1.25a mini 9 drivers...... then the netbookinstaller again?
  (#525) Old
Default 09-13-2009, 11:11 PM
I am trying to watch a baseball game on mlb.com and the window just will not resize to show the bottom where some of the icons are for fullscreen etc. Does anyone know how to re-size a flash window because the smaller res screen just will not show it. Thanks for the help.
  (#526) Old
Default 09-15-2009, 04:40 PM
Hi, Thanks to all the info here, I have managed to get audio working. However, the audio slows down, crackles, etc especially after connecting the AC adapter which I found very weird. Has anyone else noticed this? How can I fix this? Thanks for the help.
  (#527) Old
Default 09-19-2009, 02:59 AM
Is the audio supposed to work after a clean install of OSX 10.6? I followed the netbookinstaller method (0.8.2RC4) on my 10v (A04 BIOS) and SL installed fine. The only thing that doesn't work is audio (nothing shows up in the audio input/output pane).
* 10.6 was the first OS I installed. I did not have Leopard previously installed.
edit: If the audio is NOT supposed to work after a 10.6 install, can I use the kexts mentioned here?
  (#528) Old
Default 09-21-2009, 12:43 PM
Hi,
first of all Thanks to everyone on this forum and the people behind all the wonderful guides and software.
i have a working mini10v with 10.5.7 for some time. i didnt use it for like 2 months. after installing my sound worked and crackled sometimes. so i applied a fix that was being discussed at this time. but the internal mic wasnt working then (i think it was dellefi times!), so i decided to fix it and use the currently discussed method of installing Verbhelper, AppleHDA, LegacyAppleHDA and HDAenabler. In this process u have to uninstall all of the audio kexts, reboot and see if u still got audio devices. I uninstalled the aforementioned kexts that i had installed before, voodoohda and some kexts i did not know with audio in their names (reinstalled since it changed nothing) and 2 custom driver i used to fix the cracking audio. now i got none of these installed and still got working sound except internal mic!
so my question is: What can i do to either make the internal mic work or what kexts do i have to uninstall (because i still got audio and want go with the 4 kexts including the hdaenabler method)
oh ps: by "uninstalling kexts" i mean deleting them from /S/L/E and the Mini10vExt folder in Extra
  (#529) Old
IDKwutName's Avatar
Default 09-25-2009, 09:52 PM
Originally Posted by yarrn View Post
Hi,
use netbookinstaller, its the new way to do everything, remove voodoohda, use nbi, install and mic, audio should be working, and if sound after sleep stil doesnt work, use the first method in the post, 2 methods to get audio after sleep
Alienware M15x|Black|BT|GT 240m|Intel i5|Windows 7 64-bit|
  (#530) Old
Default 09-25-2009, 11:02 PM
thank you for your reply,
i got it working myself by browsing some threads here and seeing that i just had to use the updatekext thing in the extra folder. did that and installed drivers, worked. applied sound after sleep fix - everything fine!
but: almost every second time and now increasingly often im stuck while booting up: the dell logo appears, the darwin bootloader comes up and says starting system and then it hangs on the grey apple screen. try safemode?
Posted By For Type Date
